home theater (Good Bass) ?
iamroshann
Pune,India
hello ,
i want to buy home theater for my hall, which is average in size, my main concern is BASS, i want it for Music and Movies.
plz suggest me one under 50000 , right now i'm focussing on jbl cinesystem 500 si and yamaha yht 299.
guide me between these two or for other if there.
Thank you
Compare both brands in terms of features, connectivity, output and performance and you will be able to decide the best one...hope you have auditioned both with your kind of music and movies....
The subwoofers for these brands are between 6 inch - 8 inch in size and would work well in a 180 -200 SQ FT room size.
If you love a lot of Bass, you then need to look out for woofers which are minimum 10 inch in size and have good output...
If budget is a challenge, see the for sale by owner section or hi fi ads...
all the best
