UpperCut
Well, a bit difficult to describe this so I will just say How would it be - IF enclosure spikes would ALSO be used up side down / opposite site which would mean so much as that the spikes are mounted towards the enclosure so not mounted in the enclosure itself as the Images show. Maybe somebody has a productive view / commend to make on this type of using spikes as well I say as well as because this is an item, a part of my Tang Bang 8 inch woofer project which I introduced already and I will have it in a way that it could be used if need be as the enclosure has everything set out if I wanted to use it with a set of spikes.
I believe there are times & situations were this way could be suited / helpful?
rgs UpperCut
rgs UpperCut
