Initial setup of lg 32ld650
sridhar-v
Pune
My father got delivery of the tv today evening. Attached the desktop stand & connected the tv to set-top box. I got a clear white screen with a small text box showing "power mode v x.xx.xx ". It is not going into the menu or initial setup. Did not respond to remote or pressing of the menu button.
Am I missing any steps?
Sridhar
The LG technicians turned up today. They talked to their tech support & then did the following:-
Pressed the back/return button on the remote. Then reset it to factory settings. Problem was solved.
Just in case anybody faces similar problems.
