The Truth: I am really confused about the TV I need to buy. (What I want is a projector, but this proposal has been ruled out by my dear wifey). :sad:
Anyways, let me explain you my current setup and dilemma:
Living Room is of size 14ft x 18ft where I have a 40 inch Sammy LED installed (6 series model, bought 2 years back). The viewing distance is roughly 12-15 ft. On the other hand, the bedroom (Here the viewing distance is around 10-12 ft) has an old BPL CRT TV which I now want to replace with a panel.
Now the wifey wants to replace this CRT with 32 inch LED but I am thinking of getting a bigger panel instead. I plan to shift the existing LED to my bedroom and planning a 50 / 55 inch TV in the living room. I am confused as to what to buy LED or Plasma. I have been a LCD and then LED guy and have never thought of plasma till now. But price difference in LED & Plasma (of the same size) is very encouraging.
I need advice on:
1. Should I buy Plasma instead of LED? 60% normal TV via HD STB & 40% movies via PS3 (Blu-rays & 1080P rips), audio is not a deciding factor as have AVR in place
2. What size should I look at? The 40 incher now feels like a 32 incher; so bigger must be better!
3. Which brand to look for in case of Plasma any specific model?
4. I stay in Pune so any advice on best-buy location would help. I am open to buying from grey market as well (if savings are greater than say 30-35%).
Thanks in advance!!
I need advice on:
Thanks in advance!!
