budget media players for CRT:
NBox 2nd Gen
Rs. 1649/- shipped
eBay India: 2nd Gen NBOX HD TV Media Player MKV,FLV.H264. AVI, (item 110564182252 end time 04-Aug-2010 08:00:00 IST)
Amkette Flash Media Player
Rs 1990/- shipped
eBay India: Amkette Flash Media Player - 1 Year Warranty (item 250672718837 end time 04-Aug-2010 08:30:00 IST)
I am planning to get one, which one do you think is better???
as per specs..
Nbox has more video format support but only 2 channel audio out..
Amkette has limited video format support but provides digital coaxial out for true 5.1 surround sound..
you can choose depending on your collection of movie files and the audio setup..
- if you wan't only 2 channel audio and have variety for file formats (h.264 MKVs etc) go for Nbox
- if you have only divx, mpeg4 and dvd vob movie files.. and if you have audio receivers that takes digital coaxial audio input to decode 5.1 surround sound then go for Amkette..
as per specs..
If the input video file has resolution more than 1360 x 768, will the player downsample it and play, or not play at all? I have put a question to the dealer on ebay, but yet to receive an answer from him..
From Nbox's website it looks like the playeer can do a max of 720P (0r 768 vertical resoulution). It would not play/downscale 1080P.
Can anyone confirm this????
as per specs..
Got an answer from the dealer. It won't play files greater than the stated resolutions; it will display "Unsupported file".
Have used Amkette & would say that it has some limitations.
One major issue i faced was during fast forwarding or rewinding some avi files, as soon as you try to ff or rew, the video will go the beginning of file. Even going to specific time feature didn't work.
As I mentioned ealrier, your laptop will be the best & cheap option to play all types of files without headeque. You can play 1080P/ 720P whatever your laptop can play as CRT will be used as just a display unit and will set the resolutions (downscale) automatically.
