ajay124
Has anyone heard the new Musical Fidelity M6i integrated amp.How does it compare with the MF A5 integrated/ MF A5 Pre Power/Plinius 9200/Krell 400Xi?
^ Ive used A308 power amp and it was very good, A5 ive listened at a store and it was very good but i preferred the A308.
Compared to krell Integrated amps(Krell KSA power amps are a diff story though) i would say MF amps are more musical and less analytical, more lush and smoother.MF amps always have high current output which will suit many speakers very well.
Try and audition before you buy since both MF and Krell will cost quite some money.
@malvai
You just need to look around and you'll find it all there!
Yeh!I know what you say is correct.Unfortunately patience is not one of my strongest virtues!
What is your opinion of the Pathos Logos and Conrad Johson PV 14 Pre/MV 60 SE Power?
@malvai
60-70 for a decent lightly used integrated amp.100-120K for a decent Pre Power.Looking for something I can use for 6-12 months.Planning to go to Singapore in the winters to really audition EVERYTHING we keep reading about in forums/whathifi/Stereophile/6Moons.Will not spend big bucks until I have actually heard a decent amount of equipment.
It's done!
Spent Sunday mulling over the amp dilemma and the 'right path' opened up for me,late evening.I came to the conclusion that an integrated is not the way to go as it would be another compromise like the Dyn/Nad/Cyrus and pretty soon the upgrade bug would have reared its head again.So I first deleted Krell S300i/MF M6i from the list.Next to go were MF A5 Pre Power/Conrad Johnson Pre Power.And the winner by a mile is Bryston 3B SST/BP6.Hopefully I will stay put for a few years after that!I was planning to visit Chennai/Mumbai and Singapore for auditions but figured that the 60-80 K I would wind up spending would be put to better use by simply going for the Bryston.I have never heard it,but after 100's of conversations and poring over info on the net I am 100% certain that a long love affair with Bryston is about to begin.....
Will have to postpone plans of buying more CD's,as well as budget a few things here and there,but hopefully the hunt for a good system which began in January with the Dynaudio's is finally over!I am happy that I moved quickly out of the NAD/out of the Dyn/out of the Cyrus/out of the Chord/QED's.Life is short and there is plenty of music that I still want to listen to....
Is the Indian dealer willing to sell at this price?With the discontinued A5's going for 80 K(new) does it make sense to spend 150 K on what would possibly be a similar amp dressed up in new clothes.
Which one the A5 or the M6i?
@malvai
This week.
I'm curious.Why did you part with the Bryston after a few months
if you found it to be 'one of the best amps ever'?
Would like to know your impressions of the amp?Did you buy new/used?What do you feel the Krell is doing which was missing in the Bryston.Which forum member did you sell your amp too?
@malvai
'It also HOGS power and needs the A/c to be on while its being operated!'
That's a lot of external noise being added to the music.Even with split a/c there is a persistent hum which puts a 'blanket' on the music.Listening to music with a window ac is a pointless exercise.The room where I have my system has a window ac.But when I am listening to music,I chose to sweat it out in the heat with even the ceiling fan running at a low speed.I also find the sound better with all the lights off and the best sound is after 10pm with the lights off with just a small 10w bulb emitting a bit of light on my cd rack....
Have already stacked up the cd's for day 1 with the Bryston's
Clifford Brown/Max Roach at 52nd Basin Street(currently RED HOT for me)
John Coltrane A kind of blue(sorry Miles!But thats the way I view this CD)
Paco De Lucia Essentials
Oscar Peterson In Russia
Diana Krall Live in Paris
Cream Live
Steely Dan The very best of
Ashkenazy--Beethoven's-Diabelli Variations
Yundi Li--Prokofiev's Piano Concert 2
Pierre Armand--Homage to Messiaen
Bach Well Tempered Clavier
Schubert 'Unfinished' Symphony No.8(The Bryston's will live or die depending upon how they render my favorite symphony)
Mahler Symphony No 5 (Big Daddy)
