photoprashanth
While browsing through this forum I developed some interest in building an HT speaker system.
I searched for some designs with locally available items. I could not find one design with
complete details. So I had to look elsewhere to get a design which was affordable.
I came across this thread
Maurbacs NS6 MTM
I selected this because of the cost of the drivers used in the design.
Drivers used are: Aura NS6-255 ($9) and Vifa BC25SC06 ($15).
I imported these speakers using iccworld ppobox. Finally when my shipment reached me in Bangalore,
I felt they costed a bomb just because I did not know about Volumetric weight. (8K for stuff and 14K for shipment ).
Started with creating the crossover and realized that getting Inductors is the biggest problem.
So I had to build a Jig to wound coils myself.
Bought Atlas Copperwire 18 gauge. Found online calculators to find the turns and
used my Android phone as counter (proximity sensor counter) and finally could wound the coils and
measured the Inductance with LIMP software. Fortunately the coils were within 5% variations.
Polyester Capacitors and Resistors were sourced from various shops on SP Road in Bangalore.
and this is my Crossover
I connected the crossover to the drivers and placed them in a thermocol box. They sounded pretty nice and crisp.
Now the cabinet building. I decided to build the cabinet myself and bought a Router and MDF.
Built a Router table. MDF flat panels were cut and used home made Jig for circle cuts and the flat panels were ready.
This is when I realized, carpentry is not for everyone. Needs lot of DIY passion.
Once again I had to visit SP Road to get T-Nuts and chip screws (for MDF).
Assembled the flat panels and flush mounted the drivers and the speakers are ready. And port, port is a round plastic container bought from Reliance Mart and cut to measure very much close to what the designer has suggested (both dia and length).
This speakers sounded nice but boom boom..
Damping/Deadening material: The designer suggested 1" open cell foam on the walls of the box.
I had to go to Minarva circle and bought a foam and no one knows whether it is open cell or closed cell.
No body in RC road knows whether the foam they have is open cell or closed cell. As suggested by someone in the forum,
I did uffff.. uffff.. and I could feel some amount of hot air coming through the foam. I thought may be Open Cell..
This foam lining did reduce the boom to some extent but not completely.
Hence bought some pillows from Reliance mart and lined the walls as shown in the picture and the boom boom is gone.
Now I am listening to these speakers from last one month and for me, they sound great.
I also have a pair of Yamaha speakers, compared to Yamaha speakers,
these speakers sound much better and crispier. I am loving them.
If you have any queries on sourcing of materials or address of the shops where I bought the items or anything else related to build. I am happy to help.
It is just a speaker building experience from a DIY enthusiast and I am not an Audiophile. Components used are not exotic, they are just whatever is available in the market.
If you want to listen to these speakers and stay anywhere close to Hoodi circle in Bangalore can visit my house on weekends. I would be happy to show them.
Suggestions are very much welcome.
Thanks for reading..
Prashanth
Maurbacs NS6 MTM
Prashanth
