I was putting off the idea of doing a dry run on the speakers as I needed some good gasket material. But yesterday fixed the drivers using the two sided sticky foam tape available in stationary shops. IMO it did a decent job in plugging the air leaks.This listening test was mainly for checking the bass response and cabinet resonances. Each box was stuffed equally with polyester fill taken from a pillow. The drivers were connected parallel and in phase, there was no crossover and the tweeter was not connected. Played Nirvana MTV unplugged album and was pleasantly surprised at the outcome. The bass was controlled and reasonably tight. It was very close to the open baffle bass, the transient response was equally good as I put some tracks from Metallica - Master of Puppets album. The lower mids seems to be represented well and the highs were detailed. There is some real issue with cabinet resonance and I am planning to take care of it by stiffening the cabinet with fiberglass lining at least 4mm thick inside and outside.
It seems like these does not require the baffle step correction(BSC) to the extend I had accounted before. Also the fullranger having difficulty with the lower octaves when driven high with my
Sansui AU-919. I will cross the full ranger between - 200-3500 and apply BSC (3 to 6db), woofer @ 0-200 & tweeter above 3500. The band pass and low pass will be first order and the high pass will be 2nd order.
While testing the distance of the front baffle from the back and side walls were 3 feet, considering the 19.5 inch depth of the box, the rear driver is only about 1.5 feet from the back wall. I did increase this distance by a feet or two but the sonic benefits were not very noticeable.
I spent more than 6 hours listening to music last night with various tracks by Jimi Hendrix, Doors, Rush, Pearl Jam, Nirvana, Scorpions, Chris Rea, Pearl Jam, Michael Bolton & Elton John. Also tried some heavy metal numbers by Ozzy, Cinderella, Metallica & Iron Maiden. The drivers now have about 15hrs on them but they still seems to be breaking in. I think the 40hr break-in period as mentioned by Goldy is needed before any objective tests.
Regds...
