The first (experimental) phase of crossover is completed, I was tweaking the BSC circuit for the last four days days and finally settled on the values after extended listening tests. The current system seems to provide best balance between the lows and mids as per my preferences. Needless to say I am very satisfied with the results so far. The crossover is according to Plan A with the addition of a tweeter crossed at 2.5kHz.
Apart from the air core inductors, the crossover uses few 10w wire wound resistors and Keltron motor start capacitors. These are metalized poly propylene types (MPP). Decided to give a try after reading Rod Elliots experience of using these in crossovers. (
BiAmp (Bi-Amplification - Not Quite Magic, But Close) - Part 2) also thanks to goldyrathore for giving me that link. After using these caps for the past few days, I can say they are very good indeed. These are relatively cheap and available easily with varied ranges from 5 microfarad to 150 microfarad, the only disadvantage being the huge size.
Here is a picture of the messy looking xover. I need to reassemble this to a compact size once finalized
Even though the system sounds good overall with the addition of tweeter, the dip at 2kz still remains. I need a tweeter that can be crossed slightly below 2k. Ideally that translates to a tweeter with an Fs around 700hz. The Philips tweeters I use currently have a high FS of nearly 2kHz and will not be very useful in compensating for the dip at 2khz. I need to do some more tweaking before making any conclusion about the tweeter.
Republic Day Greetings to everyone
Regds...
