Need help for 5.1avr
ganapsin
Pondicherry
suggest me an entry level 5.1 AV Receiver with output of maximum 100w per channel at 4ohms. Thanks in advances
thanks for u r suggestion hemant.Yamaha 367 and Yamaha 467 and Denon 1311 support 6and 8 ohms speakers only but i need av receiver which support 4ohms
100W into 4 ohms from a AVR costing 20k would be difficult. I doubt if any of the cheaper avrs support 4 ohm speakers.
What speakers are you planning to use with this avr?
-- no1lives4ever
I am having infinity 5.1(min 40watts-max100 watts per channel at 4 ohms) speaker package with Q-UP assembled amp which i purchased in Chennai 1995. Right now my amp is dead. i need an entry level AVR fresh one or old one to drive my speakers.
