Need replacement remote for Marantz SR7001
skoka123
Hyderabad
My remote (RC8001 SR) for Marantz AV receiver SR7001 had a battery leak and it no longer works. Is there some place where I can buy a replacement remote?
Thanks,
Srikanth
Thanks,
Srikanth
If you are using Android phone, download AVR-Remote App and connect the AVR and remote to same wifi network. This works well with my Marantz SR 5007 as I lost the remote.
Thanks,
Srikanth
Not sure if Marantz app will support this model, you can try.
Check on olx, lot of remote dealers
