Newbie - HT setup
harshi_n
After research of 2-3 months , finally started with my first HT setup.
Since it was the HT for the living room , My main focus was for a tidy setup and good quality HT system which should support 3D projector in the near future.
Future plan :
LED TV - to be wall mounted so that projector screen can be dropped when needed.
Projector & screen : Epson 6100 or epson 8100 with 8"* 6" feet screen.
TV : Samsung 40" LCD - > to be upgraded a slimmer LED Tv so that it can be wall-mounted.
DTH : TataSKY HD+
BluRay Player : LG Bluray BP420
AVR : Denon 1312XP
Centre table : From Housefull furniture - 7k
Accessories : 2 Belkin 1.4a HDMI Cables & 1 Belkin Surge Protector.
I will be glad to get tips and feedback on the HT.
And here are some attached pictures of my setup.
Harshi,
Neat set-up, the Center table is perfect for the AV. I noticed the Rear's are too high on wall\ceiling .If you bring it bit down then the surround sound should be more natural.
Place the Center in font of the TV, as per your current position the vocal will be not much deeper.
Overall neat Back Beauty set-up
Thanks . Yes I plan to bring the rear speakers one level down when I will be installing the projector.Regarding the centre table when I bought it , I had not plans for HT but in the end worked out perfectly.
hey harsha i wanted to buy a blu ray player
budget 5-10k can extend 1-2k more.
i have yamaha yht-196 decodes only dolby digital and DTS
wanted a blu ray player that decodes :
Dolby Digital
Dolby Digital Plus / TrueHD
DTS Surround
DTS-HD Master Audio Decoding
DTS-HD High Resolution Audio Decoding
DTS-HD Bitstream Output
and plays 3d as well
could you suggest me some? and i guess LG bp420 does decode all this.
your reviews about it? regarding video upscaling and audio experience.?
