Opening up a speaker
Marclau
Probably a silly question but is there any harm in opening up a speaker from the terminals at the rear to look inside?
Just wondering about how the terminals are connected once you connect the wire cables?
I wont be touching the box.
Yes silly question I know..........
Dont open the speakers from any side , if the fitting is not done properly the air leaks from those openings and the sound is spoiled and also If there is a problem ,the company people will not accept the materials , since its opened already by an unauthorised person.
Was actually for the Wharfedale XR1000
I actually opened one of them from the rear unscrewing the cable mounts and slightly pulling out mount.
I then had a quick look and then proceeded to screw everything back up.
Hope this was O'K to do?
Hi marclau,
Ha ha am sure u know opening up the speaker yourself is not the smartest thing to do but since the deed is done and all seems ok u are forgiven. Actually its not so complex really but best avoided for warranty issues.
Regards.
Was a case of curiousity and nothing more........after 40 years I thought I would have a look........
Now it's time for my television...........joking of course....!!
Hi again,
Dear marclau i must remember not to buy anything u put up for sale!!!!!!!!!!Ha ha u know all said and done i quite understand this curiosity. I suffer from it too i just try and keep it under control.
