ortofon alpha cartridge verses ortofon 2M red cartridge
kalyan
hi Friends i am planning to buy Project Xpression III TT which is supplied with Ortofon alpha cartridge. I didnt get much information on that cart except that it is probably discontinued. I was wondering should i get it replaced with ortofon 2M red cart? will that be an improvement?
The 2M red is an MM cartridge. Any decent MM phono stage should do fine.
The Ortofon Alpha may be a factory fitted MM cartridge specifically manufactured for the Pro-ject range, which is why there may not be information available elsewhere. You should, perhaps, check out the sound before looking for a replacement.
Which phono stage do you recommend for the 2M cartridge? I have a lyrita audio
6c33c SET amp. will project MM phono be adequate?
The Lyrita phono stage is very good.
Rajiv
