Dear folks,
Some of you know, I have been using a Dual CS5000 TT, purchased new in 1989. It came with a Ortofon OMB 20 Cart. I have never been big vinyl person, and the TT remained lightly used. a A few years ago, the needle fell off, and I then got a Shure M97xE. Contrary to some views, this Dual has been a lot better than the modern entry level TTs. In my view, Dual missed the boat and came up with their best TTs past 1985, by then the CDPs came into the picture and the better Duals somehow lost prominence. I was using this TT lately with a very modest CA 640p phono-stage which is again good for its price of INR 7K. Unfortunately, the TT motor has failed for a second time, and it's not easy to get it repaired immediately. Anyway I am not throwing away my Dual, and if I can get it repaired, I probably will gift it to my son for his personal use in his room.
Finally, I have taken the plunge and have ordered a new TT. It is the Cello from the German brand Scheu. At the moment I can only afford a Rega RB250 arm and a MM cartridge (Ortofon Super OM 30 which has a nude fine line needle). I have considered, for the last year and a half most of the usual suspects like Pro-ject and Rega; even considered the VPI Scout for a short while and the Clearaudio entry level ones. Finally I settled for the Scheu Cello, because this seems to be a serious TT within the amount I am ready to spend now (already with a stretched budget). This has the same bearing as the more well-known Scheu Premier and the material for the platter is also the exactly the same, just a bit thinner. I think the motor is also the same, just that it is placed in one of the feet of the Cello, instead of being separate from the plinth. BTW, singer Katie Melua has a Scheu TT.
When my new TT arrives, I will post the pictures and my impressions in an appropriate thread. If I like the TT and the format, I may later upgrade the arm and the cart.
But now I realize the new TT perhaps deserves a better phono pre amp. I am not in a hurry to get it, but eventually in a few months it is inevitable, I think. The first thing I will do is to borrow the Ray Samuels Nighthawk from Vasu (myriad) or Pratim for a few hours. These are unbelievably nice people, and so I am assuming they will do the favour. This will set some kind of benchmark for me and will show me the areas of improvement I can expect from a decent phono stage.
I need suggestions for phono pre-amps. My amp is a EL-84 based Japanese product, called Leben CS300, and my speakers are 22 year old Canton Karat 60. I consider the amp-speaker combo to be a strength in my system.
My budget is strictly upto USD 800 (to include the Nighthawk), the lower the better. I like natural tone with transparancy. BTW, I am looking for only SS phono stages, because I already have tubes in my amp, and for the moment that is enough I think .
The ones I am considering:
1. Ray Samuels Nighthawk
2. Lehmann Audio Black Cube
3. Graham Slee Era Gold V
4. Trigon Vanguard II
5. Jasmine Audio LP2.0 mkII
6. Promitheus Audio phono pre
The 4th and the 5th above are relatively unknown. The Trigon was suggested by the Listening Room, Bangalore from where I am getting the TT. The Jasmine is a Chinese product. From whatever information available on the net, the Jasmine is a marvelous little product at around USD 600. The Jasmine and the Promitheus both come with separate power supply at USD 600 or under it (in case of the Promitheus).
Any discussion or suggestion of the above or anything else will be highly appreciated.
Regards.
Regards.
