project debut 3 cartridge upgrade?
the_canuck10
toronto
I currently have:
Wharefedale 10.2 speakers
NAD 316bee integrated amp
NAD PP-2 phono preamp
Project Debut iii turntable
HRT Streamer 2 DAC (macbook pro)
What is my most logical upgrade from here?
is it the cartridge in the turntable? its an ortofon OM5e
I think a good upgrade for you would be the Ortofon 2M Red.. it pairs pretty well with your table.
Hi Your amp looks more than adequate. The new cart will also increase the output marginally. If your old cart sounds good on this setup the 2M will definitely take it a notch higher. Best of luck
Abhijit
