Soundbar for below 30k
kratu
AP
I'm interested in getting a Soundbar or a speaker for workplace. Mostly for mood setting background ambient/soft instrumental music.
Anything below 10k would be great. However, I can stretch it to 30K for really deserving piece of gear.
Source is an iPod Touch. It would be good to have Wifi, USB or bluetooth connectivity. I intend to stream from Apple Music. The bit rate is low; so I don't need an audiophile class speaker.
One of my friends mentioned about Logitech X300. I've also read about KEF Muo. Any other recommendations would be helpful. (One constraint is availability for audition in Bangalore).
Check out a few Yamaha's. I would on the contrary suggest the Bose soundlink and the likes from Denon and others. Compact and excellent for the purpose you are looking at.
Have you checked out this adapter? Amazon.in: Buy Logitech Bluetooth Audio Adapter Online at Low Prices in India | Logitech Reviews & Ratings
You could pair up any 2.1 speaker system such as Panasonic HT20, Sony SRS-D9 or Logitech Z-623 2.1 THX-Certified. Either of these pairings would keep you within your budget of 10k. With an iPod you have access to wifi as well as Bluetooth.
You could team up Powered Studio Monitors with this adapter or even have a pair of bookshelf speakers connected to a stereo amp. Lots of options to choose from.
MaSh
I recently bought an iGo SB300 well under your budget. Its very good value for money. Built like a tank and sounds good too.
Hi Kratu
Check out the Samsung Soundbar which is wireless within 20k officially (J450), it sounds good for music and movies.....works like a charm.....i am sure with hard bargaining with dealers, you could possibly get it for 17-18k.....
Hi Kratu:
Since you can stretch your budget, I would suggest the newly introduced Bose Solo 5 Soundbar for Rs.22,000/-. Bought this a couple of weeks ago and the sound quality is superb, far better than Sound Link Mini.
It has Bluetooth and also has Optical, Co-Axial & 3.5 mm Aux Inputs. Wall mounting brackets are sold separately.
Unfortunately, in Mumbai none of the Bose stores or Croma had this on display/demo and I had a gut feeling that this would sound good since I didn't want a Sub.. Trust me, I am really happy with the purchase as it is very compact against the much much bigger Yamahas.
Try with some JBL range such as SB-350 or SB-400. I am using JBL Soundbase 2.2 it's a great little compact system.
This is how my JBL sounds.....
https://www.youtube.com/watch?v=Xm03nR5PWhQ
