speaker for denon 1513
rahul j
nagpur
i got my denon 1513 and yamaha sub yst012,
so urgently required speakers for this(only online)
i shortlisted follows
1) boston acoustics a26(20k) and boston acoustics A 225C(13) and buy rear latter
2) polk audio tsi100 (two pair 24k)and cs10(10k)
3) yamaha Ns-333(15.7k) and yamaha Ns-444(10k) and rear please suggest
4) Wharfedale DIAMOND 10.1(19k) Wharfedale DIAMOND 10.CC(14k) and rear buy latter
please help me
thanks
please help me
thanks
You can also consider Sonodyne Sonus range of speakers... Assuming your budget is approx 35K....
Sonus 1501 BS (11K) + Sonus C2501 (8K) + Sonus Rears Dipoles (12K)....
i am not getting any sound from led to avr,
what will i do,
can i connect led HDMI out to avr HDMI in ?
or connect optical cable?
please help
thanks but can sonus sound quality as good as boston a26 or diamond 10.1 ?
Yes it can.... I have used both Diamond 9.2 & Sonus speakers.....
Sound is very subjective... I for that matter don't have any....
You can take a call which suits your requirement..
i my finally decide
boston acoustics a26(20k) and boston acoustics A 225C(13) and Sonodyne Genie 1(8k)
or
Sonus 2504 (22K) + Sonus C2501 (8K) + Sonus Rears Dipoles (12K)
please help me to chose above two
thanks
arc not supported for denon 1513
If you TV has Digital Optical out/ SPDIF Out, connect it to your AVR... You should get the sound now...
i my finally decide
or
thanks
If you already own a sub, then you may choose a BS.. Once you set the crossover in the AVR, your sub will do the job perfectly...
thanks for your suggesion
I order boston acoustic tonight but for rear sonos is good enough for BA?
