Speakers for the projector room
soamz
Dubai, UAE
Hi, My current audio setup is,
Denon 2113CI | Polk RTi A5 | Fxi A4 | CSi A4 | DSW PRO 660 | CHORD Speaker Cables
Im looking to get Polk Bookshelves pair , so I can use all the 9 channels on 2113.
My room is 14x20 . Is the current system enough to boom it ? :indifferent14:
Sorry , 2113 is 7.1 channel supported AVR.
I have the current 6 being used. More 2 channel are biamped to the FS .
So, I will take them out and put them on the bookshelves for more surround.
Right ?
Hi Soamz,
Why don't you go for another pair of Polk Fxi A4 for the Ls and Rs? It is usually recommended to use the same model speakers for all surround channels, so that you will get a uniform and seamless surround sound. If for some reason if you want to go for some other model, then get some speakers from the same RTiA series from Polk as speakers from the same series would work well together.
You can go for Polk RTi A1 or A3 as they are from the same series and they will integrate well with your existing speaker setup :thumbsup:
