Hi there,
I am looking to buy a split AC for my house (Delhi) and was wondering if I could get some help.
1. Room dimensions? Drawing room approx - 13 feet * 19 feet (and it is open layout) ; lounge - 7 feet * 10 feet
2. Which floor is the room in? - 1st floor flat
3. Is something constructed on top of the room? yes another floor
4. Sun facing portions on the room ... walls as well as windows? - sun facing wall for half of the day (afternoons) it gets direct sunlight and has a veranda where the external unit will be
5. Usage - approx hours and months - it will be used mostly in the evenings and the weekends
6. Looking for both heat and cold function as Delhi gets pretty cold during winters
7. Not sure if there is a dual splt AC so that the other unit could be used in a small lounge area adjacent to my drawing room.
8. Looking for either Daikin or Hitachi
