sound_maestro
Hi All
I calculated my peak input of HT setup to ~850 watts and was about to buy a Vguard stabilizer when I read this:
from Reviews V-Guard Crystal Plus Voltage Stabilizer Voltage Stabilizer - Latest Review of V-Guard Crystal Plus Voltage Stabilizer, India | Flipkart.com
Can some one clarify please if its really worth to buy a stabilizer or a belkin surge protector be enough?
Transformer Tap Changing AC Voltage Stabilizer
Output Voltage 200 - 240 V from input 167 V - 290 V
This means output voltage will be fluctuating in the range 200V - 240V according to input voltage. If input 167V then output 200V and if input 290V output 240V. But this is not accurate as these stabilizers use tap transformers which simply adds or subtracts some fixed voltage usually 20V, 40V etc. If input 200V 20V added and output 220V , If 240 input 20V reduced and output 220V. The main drawback is voltage threshold for switching may be set on some fixed voltage say 211V so if input 210V 20V added and output 230V if input 212 no switching. So if input voltage is slowly fluctuating in the input range 209 - 214V then output it provides is 229V - 214V that too instantly not gradual which actually harms the electronics device rather than helping.
This model is rated 3 Amps so some 600 VA (~220V x 3A) max load can be connected without straining the transformer.
These kind of stabilizers is not needed for any electronic device and instead connecting some surge protector is far better.
One I would recommend is this, Belkin 8 Socket Surge Protector
Online Shopping India - Shop Online for Books, Mobile Phones, Digital Cameras, Watches & More at Flipkart.com
It have surge suppression from cable, phone, network lines too.
