My reccs FWIW;
-Charger:I bought a Sanyo smart charger model NC-MQR02N-UEX-SS
for Rs800/- 2 years back from a camera/accessories dealer in the wholesale market in Chandni Chowk, Delhi.Google will show up many chargers but this one is a legel import with a 1 yr warranty
Its truly a great charger-compact ,reasonably fast(2600mah nimh batteries in 4.5 hrs) & has several layers of overcharge protection built in -google for details.
It can charge 4 AA cells or 2AAA cells, nimh or nicd.
-cells: I have been using 2600/2700 nimh Fuji rechargeable cells for my digital camera.
A set of 4 cells fully charged gives me 450 to 500 shots on my Canon A 620, depending on the mix of flash/w/o flash shots.
I picked up a set of 4 2700nimh fuji cells for Rs 450/- from the distributor in Nehru Place, New Delhi abt a month back.
-Re the cell types for various applns-
-For digital cameras, nimh without a doubt.
If you use your digi camera quite frequently, pick up standard, high capacity nimh cells.
But if you are a casual photographer, pick up Sanyo Eneloop-2100 mah ( Fuji also makes similar long charge holding cells, forget their name).They will hold a charge for much longer & not go bad.Normal nimh cells have a tendency to die if not used/recharged for a few months.
- For devices e.g clocks/timers/remotes etc which do not use much current, go in for Nicd cells(AA or AAA,as reqd) 800mah or 1100 mah capacity( I've used uniross/fuji & both have worked out well); nimh are not suitable in such devices.
However, plz remember that nicd cells exhibit a "lazy battery" effect if recharged frequently w/o the existing charge almost fully draining out(google to understand this more.
Hope this helps.
