D
Deleted member 17547
Guest
All,
I purchased Paradigm Monitor few days back.. Currently using them with CA 650A..
Overall sound is good but a bit harsh specially when i listen to Rock.. Basically combo is good for soft songs but not at all suitable for rock.. When i bought these speakers i felt the same but since overall sound was good i bought them thinking that after some hours of play they'll settle down.. but seems like that ain't happening.. speakers are sounding same after 3 days of running.. 7-8 hours daily..
So looking for a AVR or Amp which is perfect for these speakers.. Would prefer AVR as that was my initial plan "less components".. that's why i started a sale thread to sell off my audio video stuff...
Preference is Music.. can comprise with movies.. Have read somewhere in forum that Marantz go well with Paradigm so thinking of trying Marantz SR5005.. or should i go for higher models to get a good music performance..
Budget.. Max 40K.. have already spent too much on speakers.. way out of my budget..
Thanks in advance for the suggestions..
