sanjay0864
Your definition of 'HD Ready' is exactly what it was supposed to be. Back in the days when the first HD TVs were introduced there was no standard for digital HD broadcast TV in the US. Thus, when the ATSC HD standards were finalized and the first HDTVs with built in digital HD tuners started arriving the industry needed a term to differentiate HDTVs with built in digital HD receivers from the older HD TVs that did not have built in digital HD tuners. Thus the term 'HD Ready' was invented to define HD TVs without digital HD tuners. Then, some 'brilliant' marketing people totally distorted the meaning of the term and started using it to to define TVs that have a resolution of greater than or equal to 1280x720 but not 1920x1080. To add to the confusion, when Sony first introduced their 1920x1080i camcorders, they used the term 'Full HD' to highlight and differentiate from the earlier camcorders that were only capable of shooting 1280x720 resolution. Thus the result of all this is, that today, atleast in India and if I am not mistaken, elsewhere in the world too, the following terms came to be:At least in the USA, "HD Ready" meant a TV that can display in HD but does not have a built in HD tuner / scaler, etc. Meaning, you cannot catch off the air HD broadcast and you'll need a STB. If this is the same terminology used in the Indian market, then why should the quality differ between HD Ready and HD TV? Since most people use STB, TV manufacturers are saving cost by reducing the hardware and that makes a lot of sense.
HD Ready - HDTV set capable of accepting HD signals (may not be able to display at full resolution 1920x1080)
Full HD - HDTV set capable of accepting HD signals and able to display full resolution at 1920x1080
720p HDTV - another name for HD Ready HDTV
1080p HDTV - another name for Full HD HDTV
Note:-
The ATSC HD (USA) standards define the following resolution as HD:
720i - 1280x720 interlaced
720p - 1280x720 progressive scan
1080i - 19201080 interlaced
1080p - 19201080 progressive scan
PS: LCD and Plasma are 'fixed' resolution technologies. Meaning a LCD or a Plasma can only display one fixed resolution, which is defined as the 'native' resolution of the TV. Thus irrespective of what all resolutions the LCD/Plasma TV may accept, the signal has to be either upscaled or downscaled to match the 'native' resolution of the LCD/Plasma TV. That is unless the input signal matches the 'native' resolution of the LCD/Plasma TV.
