Tata Sky signal problem
I have found this problem with my projector. It seems, Tatasky signals refresh rate changes. HD signals are provided at 1080i not 1080p. Refresh rate of 1080i is 50 hz. But I noticed changing these to 25 hz. Whenever, this happens, tv take few sec to adjust picture acordingly. That is why a blackout.
I had problem with couple of channels, it was showing that STB is not receiving signal or due to weather conditions but other channels were working fine. Ultimately I called to TS, Engineer checked and found that the LNB was not working properly on the equipment they had. Its beep was not frequent and sounding with a long gap, moved/adjusted the dish but no luck. Finally he declared that the LNB is weak, and we have to change it. After changing the LNB, everything became perfect, the beep beep and the channels too. :lol:
I have paid 150/- only for new HD LNB (4 slots, I have 2 SDB and 1 HD PVR)
Well I have Tata sky installed. Now in some of the newer channels which have been introduced I get a message like your settop box is not receiving any signals please check ...... but on changing to other channels I am getting perfect sound and picture. I am connected to a master dish on the society flats. Just yesterday I saw a Tata sky fellow at my neighbours flat. I asked him about it and he stated that the LNB needs to be changed on the master dish and this is being undertaken by them and after this is done these problems will disappear.
