where to buy crossover components in Bangalore
Capacitor (bipolar) and Wirewound resistors are available in SP road. But you will have a problem in getting air core inductors which are required for crossovers. One needs to wind them patiently.
Finding DC capacitors is a problem. I was looking for 20mFD and had tough time finding one - checked atleast 15 shops and finally borrowed from a friend thinking I will import. Then one day, I found EPCOS make 10mFD and 20mFD in a shop when I had actually gone to buy resistors. I think shop was called Kanchan electronics. I can PM you directions if you want. What values are you looking for?
I am told you could also try capacitors used for running motor-pumps. Look for motor-run and not motor-start.
EDIT: Kanchan not Kailash Electronics
you can check kanchan, keltronix, amar radio, vishal etc on SP road. for caps, you wont get polypro, but you can get polyster caps, other wise NPE is always there.
got this from a fan repair shop will it be ok
