yamaha RX V-667 & Sony BDPs-370 & Ipod doc
isoton
chennai
This is my HT setup. My queries
1.Playing audio cd in the above set up will be less enjoyable compare to playing it with a dedicated CD player?
2.I want to enjoy FLAC file music is it possible with this set up or i have to
use my computer desktop & corsair sp2500 2.1 set up
3.No knowledge about FLAC files ? can i down load it from net, since i have unlimited Brodband.
1. A dedicated CDP will definitely enhance the music listening experience.
2. Most bdps won't play FLAC files. You can use your desktop computer for FLAC playback or buy a hd media player. If your desktop has hdmi or optical/coaxial outputs then you can connect them to the AVR.
3. Read Free Lossless Audio Codec - Wikipedia, the free encyclopedia. You can download FLACs but discussing them is banned here as it amounts to piracy.
Thank you friend,
For throwing some Light .
In future i am planning to buy some budget DAC like Nuforce Udac2
then try to learn this FLAC stuff.
