I recently bought a Yamaha RX-V373 during a short business trip to USA. Just a brief review for the interested people.
These were my requirements at the time of selection:
Price range - around $200. I bought this for $210
Weight - lesser the better (since I have to carry from USA). This one is 7.5 kg
4HDMI inputs - For tatasky+, xbox, wdtvlive, BD/dvd player.
My preferable list (not mandatory)
Operating in 220/110v. This one does not support. I am using a voltage convertor.
I wanted to use my existing speakers for sometime before I budget for better speakers. This supports both 6/8 ohms speakers.
USB/IPOD support. This one supports without any additional accessory dock.
Audio return channel. This one supports. but I have disabled it.
Now on to the review:
Looks : Not of much importance to me. But this has a decent good. It does not look very sturdy on a closer look. But I cant complain because I wanted a light weight one.
Setup : Setup was a breeze. Enabled vierra control in TV. Changed the speaker impedance to 6 ohms. Connected 5 speakers (no sub woofer), YPAO MIC and HDMI out to TV. Powered through 110/220v convertor and powered on. It detected the YPAO mic and I did a setup. After a brief sound session, speaker configuration is complete !
Switched off. Disconnected YPAO, connected tatasky+ and switched on. Display came up. But no sound. Later I found that with HDMI control on the system is behaving in a weird way. Based on which is switched on first (TV or receiver), sound will either come in TV or receiver. Disabled HDMI control in both TV and Receiver and everything is fine.
Sound:
Configured speaker settings such that bass comes out through front speakers (since I dont have a sub woofer). Tried Star movies HD and sound was decent for this configuration. I dint expect high bass anyways. changed to SD channel and tried different Dolby and neo to change 2 channel to 5. Neo-Music mode seemed to be suite my taste.
Overall, sound was decent considering the entry level speakers I had.
Other features about the receiver:
HD Audio decoding available.
4K pass-through. Dont need now. Just in case for later use
Front panel ipod dock is very convenient and works like a charm. No accessory needed.
YPAO automatic speaker setup seems to be quite effective. I am not an audiophile.
ECO operation consumes 20% less power. Not sure of its effect in audio.
Dynamic Range Control is wonderful for TV. Whispers are loud enough and no sudden increase in sound for advertisements.
Negative:
Would have preferred ability to use HDMI passthrough when the receiver is off.
HDMI-CEC creates issues. It could also be due to my TV. Disabled CEC for now.
Dint test:
With subwoofer.
HDMI - 3D
Radio.
When compared to previous model RX-V371, these are the new features in RX-V373:
ipod dock, YPAO, ECO support, onscreen display, 4K display.
I think RX-V373 is not yet available in indian market. If it is available, then it is a good upgrade over RX-V371.
Let me know if anybody wants to know anything in particular about the receiver.
Sound:
Negative:
Dint test:
With subwoofer.
HDMI - 3D
Radio.
