Z506 vs F&D F6000..Urgent
Raghavan sridhar
India
Guys I have decided to buy this for my friend. He will be using it for PC. Aim gaming movies.. He will buy any AV receiver. He has asus xonar dg sound card.
So which one is best in this..more or less both are same price. I could not buy edifier as its not available in any stores and spending 6K more than the speakers I mentioned also will not make much difference. So kindly tell me which one to choose. I'm planning to buy this today or tomorrow based upon the choices u give. Thank u
dude fenda no where sits closer to z506..
either do a comparo of edifier and logi.. if budget permits between the two..
logi is way better than fenda.. however budget decides manay things..
There are 148 views but only one reply till now... I need help guys.. Wat happnd to the forum nowadays no one is replying in any thread. I think it was very active before 3 months... but now it is hardly active.. sad
How can one make suggestions if he has no experience with these speakers? I suggest you to demo the two and decide accordingly.
R u by any chance trying to say that a website with this much popularity and the members are not aware of logitech Z906 and Z506 which is running in the market.. Oh come on man... plz... they are from established brand rite... I thought many would have experienced in it...
It may be true that this forum has many members having experience with z506 or F&D6000. But my question is that how many of them have tried the two side by side? Only your ears can decide what is better for you.
Since you now ask for Z906 and 506, I would suggest the Z906 as it has digital inputs with onboard DTS and Dolby Digital decoding. But isn't it way over your budget of 6K?
Us it costs 16K but I have no other options other than that.. If at all I need to buy a 5.1 it costs more than 25K.. I dont want to spend that much bcoz im not an audiophile... I just need some booming bass and feel the 5.1 thats it... so I preffered going for a branded one... I have skipped F&D too as I don't want to take any risk... I bot one 5.1 for 5.1 and its not at all good. Its not a branded one.. SO I have decided to go for branded this time... z506 or z906...
well to be true if budget speakers comes in picture.
go ahead with closed eyes for logi's /altec/edifier.. stay away from creative budget series.
have never seen fenda or heard in real so cant comment but all i know is it wont better logi's or altec in anyway..
loudness can be there. but depends how clean is it able to deliver it.
the logi's wont crackle at higher db's ...fenda might.. demo the fenda and see if it can work out for you.
Go for Edifier C3. It costs around 9k at Flipkart.com
See the link below
Edifier C3 | Speaker | Flipkart.com
