sabret00the
Hi All,
I know that there a bunch of ALTO/small car ice threads around but I created this thread since I'm in doubt about a few things.
Issue:- Not happy with the sound quality of the current setup. Although the setup sounds okay at lower volumes but base falls completely flat and sound breaks when I increase the volume to about 40-45 (max being 62). Sounds like a Road side setup and ruins the listening experience.
Current Setup:-
Pioneer DEH-7950UB
Front - JBL GT5 402 - Dash mounted
Rear - JBL GTO 937 mounted on installer provided MDF Plank
God knows what wiring.
No damping off course.
Plan to do:-
Retain the HU & the rear speakers (GTOs). Dont want the MDF anymore since that saves me a lot of space.
Want any front speaker (read compos or coaxials) that would give me good sound output. Something that will not break when volume is increased. I dont mind if it is not that loud.
2nd dilemma - where to put the rear co-axials now that the mdf is not there.
3rd dilemma - Do I need an amp or a sub for my tiny little car? Never had one & hence not sure how will it sound? Open to the idea though.
4th doubt - Do I need damping? If yes then which brand? What about wiring? How important is that? Which brand again?
Last dilemma - My budget for the above is 10-15K (+/- 2-3K) & where to get this done in Bangalore so that I drive out with a smile on my face
Current Setup:-
Pioneer DEH-7950UB
Plan to do:-
