AVR Pricelist
^ im not audiophile enough to comment on the various pros and cons, as i upgraded straight to that from tv speakers :D
Just that i'm satisfied with the purchase...
I Purchased Yamaha Rx-V675 from vipul audiotech. for Same 52k. yesterday (11 jan 2014)
the prob is i have old samsung 29 inch tv, which dosnt support HDMI :sad:, i looking for an HDMI to Component convertor,
anyone can please suggest me an convertor, which supports the v675 avr :rolleyes:
What are your sources? BDP? STB? Why don't you connect them directly to TV using component out and use HDMI or optical out to AVR for audio?
Congratulations!
Such a converter is available, though not cheap.
HDMI to Component convert | eBay.
But why would you want such a device? You could use the AVR component monitor out connection using a component cable and a stereo cable much more cheaply.
For my STB, and i dont have a optical out option in my tv nor in my STB.
the probs i dont know to change any spreakers setup. i hope it can be done only by a on screen mode. pls correct me if i am wrong.
pls suggest me any way to go to speaker setup , Eq settings.
Congratulations!
i do checked the internet, i found many convertors, my doubt ,will it work properly.
there may be any member who tried this option, can help me on this
Google for vipul audio tech kilpauk or grand cinema kodambakkam...
Have you decided on denon... Because i heard currently there is no service center for denon in chennai, or the denon service here ships to somewhere else or something like that... So make sure you have local service backup and then buy
Thanks. Just called both. Vipul has offered a call back as sir? was not available. Grand Cinema is quoting 51k as the best price and service would be done at their store, both during and after warranty. Now I have to think twice before buying it online or abroad! (one of my friends is going on a 2 weeks trip to Dubai)
I have not 'decided' on Denon as such but from what i've read, it seems to pair well with Polk. I only have a pair of Polk Tsi200 and a PSW110 SW now. I will be getting a pair of RTiA7s soon :) Also the X2000 has Audyssey MultEQ XT.
