Hi gobbel,
found this- essentially says what you say-
Optical Tables : FormelTM Granite-Honeycomb Structures Technology
* Combines the vibration control performance of honeycomb construction with the flatness of granite
* Air-bearing compatible
* 50% to 70% lighter than solid granite blocks
* Custom sizes, shapes and mounting holes available
FormelTM Granite-Honeycomb Structures combine the vibration control performance and light weight of steel-core honeycomb construction with the unparalleled flatness of granite. The result is the finest table tops and breadboards ever offered. The granite work surface maintains flatness over the entire tapped working surface within 15 microns over one square meter.Formel structures can be fabricated with or without tuned damping.
Standard construction is without mounting holes. Sealed mounting holes on 1 inch or 2 inch centers are available, in addition to metric and custom hole patterns. Class 100 cleanroom-compatible Formel structures are also available.
Granite-honeycomb hybrids also offer the following advantages over solid granite structures:
Higher dynamic rigidity
Because granite-honeycomb hybrid structures are much stiffer and 50% to 70% lighter than solid granite blocks, they offer much higher dynamic rigidity for unsurpassed performance in applications requiring immunity from vibrations.
Tuned damping eliminates "ringing"
Solid granite is particularly notorious for its "ringing." This structural vibration reduces the accuracy of precision measurement and positioning systems. Damped Formel structures include multiple tuned dampers, each individually tuned by a skilled engineer to minimize motion at resonance modes.
Less chance of "hot spot" formation
The lower thermal inertia and higher thermal conductivity of Formel structures aids in preventing formation of "hot spots" on the work surface which can degrade the performance of instruments in applications that are sensitive to thermal variation.
Reduced weight
Because a Formel structure weighs 50% to 70% less than a solid granite block of the same size, you benefit from reduced shipping costs, easier installation, less demanding floor construction requirements, and more convenient transportation.
Easy customization
Formel structures can be easily fabricated in almost any shape for special or OEM applications. Some commonly requested custom capabilities include special thicknesses, mounting hole patterns, honeycomb core materials, special flatness specifications, and tight hole-to-hole tolerances.
To learn more about how a Formel structure can solve your vibration control problem, contact your local Newport representative.
FormelTM Structure with Tuned Damping (Left), Solid Granite (Right)
