Nice. I was searching for a box like this for the same purpose. Could you please share where you bought it from?Though i got the Power outlet wall Panels and Power Receptacle Sockets long back, i was waiting for the Bottom box which i recd yesterday.
Have to assemble them and check.
Along with these i will be doing couple power cables for which i have all the parts.
One with 17 dia mm cable and the other Lapp Olflex Classic 110 CY 3 core 2.5 sq.mm cable which i got from Mahesh (mpw).
Oh.. Thanks. Any leads in India?![]()
2.96US $ 60% OFF|Minitiger External Mounting Box 258mm*86mm*34mm for 86 Type Triple Touch Switch or Socket Apply For Any Position of Wall Surface|Dark Box| - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
Not that I know of...Oh.. Thanks. Any leads in India?
You can safely use 120/125 volt receptacle with 220/240 volts going to it... the voltage is twice as high and that makes the operating current twice as high...Is that wall socket rated for 220V? States 125V on it.
Thanks Shobit!Wow looks absolutely amazing.
MaSh
Doc, they are heavy duty connectors which can accommodate 19mm cable.Looks quite neat, the connectors are quite impressive.
Is it Siltech Copy Cable from AliExpress?
Thanks Shobit!
These are the links:
US $11.0 |Hifi audio SPX Silver Plated Power cable shielded high quality silver plated power cable diy bulk power cable|bulk power cable|viborg audiodiy power cables - AliExpress
18.0US $ 10% OFF|Xssh Yivo Audio Grade Gold Plated Iec Pure Copper Connector High Performance Female Male 3 Wire Grounding Us Eu Ac Power Plug - Electrical Socket & Plugs Adaptors - AliExpress
Did You Wire it in Parallel that is Star Config?power receptacle socket box
Or in Series?
Your craftsmanship is amazing, especially the power cables look quite professional, pure art!
Looks very good, it sounds very good too. Currently I am using this with Marantz AVR, Very happy with the performance.Thanks Doctor,
the wiring is in series.
This is the last cable i finished today, end of... trying out McIntosh green cable per your suggestion...
