DIY - SPEAKER BOX ...help....ASAP
Non_Techie
Hyderabad
My question is if i use the specifications on the below page..
IWAI :::::: unique solution for audio system ::::::
(this is just an example basing on this i want to build others too)
can i be able to build speaker box...do i need any thing extra...also...what
software would help me to design my speaker cabinet.
And also need detail procedure to build a Cross over.
Thanks,
Non_Techie
Firstly, I suggest you read quite a few speaker build thread available in HFV.
Secondly, having read and assimilated what is available, PM DIY speaker gurus like Shershah, Anilva, Anilkumar, Goldyrathore, t.anthony, Rajiv (Am I missing some names?? Purely unintentional it is)
Thanks,
Non_Techie
You will need the speakers Thiel-Small parameters to design a speaker cabinet with these parameters. Download software like winisd and go through their tutorials and this will help you to familarize with all the important parameters to design a speaker cabinent. The speaker cabinet can be sealed or vented design. With the attached link you can go-ahead and design a transission line speaker cabinet as the driver is full-range and you do not have to worry much about the cross-over network too. TL Speaker design do not rely on the TS parameters and the only important parameter will be the driver resonating frequency and the Qtc of the driver.
All the best with your DIY effort.
