Go Deeper with Rel R-528
Decibel
Chennai
Go Really Deep with the Rel R-528!!!
[IMG2]http://img217.imageshack.us/img217/3728/relr528.jpg[/IMG2]Serie R was conceived as a maximum value proposition in the entire REL product range possessing many of the performance attributes of Rel's legendary Reference Sub-Bass Systems. The R-528 represents the final step-up in the Serie R range and e1mbodies the largest model with superlative depth, scale and slam. The R-528 receives a Heavy 12" active bass-engine coupled to a VariCone(TM) 12" carbon Fibre ABR passive radiator producing the equivalent of a 16" driver in an even larger cabinet. The digital power amplifier produces an effortless 500 watts enabling the R-528 capable of underpinning speakers with quality low-frequency extension that cost ten times its own price. The R-528 is all about speed and detail as reproduced by the Heavy 12" active driver, which is actually the fastest diver in the series with the best impulse response. The R-528 can go down to 21Hz.
'The Piano's majestic scale is not only more completely rendered, it sounds like it is playing in a concert hall instead of my home theater', say Steve Guttenberg in Home Entertainment.
I'm interested in the pricing too.
I've been debating between getting a TT + PhonoPre and getting a good subwoofer for music.
Hi Decibel,
I have a suggestion(like others),you may please always post prices of the products(showroom).
Special one can be shared with interested/serious buyers by PM.
Cheers.
The Rel R528 has an MRP of 1.32L.
And to answer your question, no it does not have room correction, but it does have a number of adjustments that can be used with your other electronics. Here are the specs fro Rel's website:
REL Connectivity
A special proprietary REL High-Level Input cable is provided with each REL Sub-Bass System and is the preferred method of connecting the REL to your main speakers. This cable joins the REL to your system by connecting to the left and right channel speaker terminals of your amplifier or surround-sound receiver. This allows the REL to receive the exact same signal as your main speakers, providing for a seamless integration of low frequencies into your system. This is a very important point and together with REL's Natural RollOff circuitry, ensures far superior system integration of the Sub-Bass System with the main system. The High-Level connection is active whether you use your system in two-channel music or surround-sound mode. This connectivity method offers noticeable sonic improvements over the common RCA low-level interface by not only delivering the missing low frequencies by creating the realization of a "lifelike illuminated acoustic space", otherwise known as the "REL effect." Virtually any conventional separate power amplifier, integrated amplifier or receiver can be used with REL Sub-Bass Systems. Even most Class D amplifiers can interface as REL incorporates REL-D circuitry providing the appropriate impedance and grounding for digital amplification.
REL Theater Reference
In order to take full advantage of the Low Frequency Effects channel (LFE), a channel intended for low-frequency content in film soundtracks, REL provided a .1/LFE input. Most multi-channel processors or surround-sound receivers incorporate a special subwoofer output that bypasses any internal crossover circuitry. It is with this output LFE content can be accurately reproduced and controlled independently of the High-Level input signal. Additionally, both High-Level and .1/LFE signals can be used and adjusted simultaneously in a multi-channel system. By supporting both main, centre and surround speakers with bass reinforcement, your system will sound more realistic, musical and alive through improved dynamics, range and scale of the music or film score.
R-528 Key Model Features:
  • 3 Separate Rotary Controls for (1) Hi/Low Level (2) .1/LFE Level (3) Crossover Frequency.
  • Dedicated inputs for Hi Level (Speakon), Low Level (RCA and .1 (RCA).
  • Extremely low crossover points that allow "seamless" blending with any loudspeaker.
  • Proprietary REL-D digital amplifier input provides the appropriate impedance and grounding environment for most Class D amplifiers.
  • Piano Black Lacquer Finish.
