Im new here im looking for a budget of 60k a good home theatre for dolby audio content ,i thought of buying q900c but some say home theatre setup is way better
If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
Its a tight budget . You csn buy denOn x250 bt for 30k and rest for speskers. You can add sub later.
If you streach you budget a bit bur polk t50 package .
First get two good speakers and a subwoofer. Buy used from olx . Also buy an AVR from the early 2000s - they are good value since they are outdated but since the manufacturers spent more on sound than HDMI, Arc and other codecs, they are more robust electrically. Focus on the system for some time. Then later add to it. Don't go to a showroom and buy a huge 5.1 system of poor quality plastic home theatre in a box speakers
Buy used bookshelf speakers and a stereo amplifier for the time being.
Add a used subwoofer later.
If scope for 5.1 is there at your place, buy a used avr.
That would be money well spent.
Pm me for any other details, I am from Hyderabad. Best of luck.
