Help needed to build Home Theater
sabharinath
Hi, I'm planning to get different components and build a HT. So far, I've narrowed down on:
Receiver: Denon AVR1911 or AVR1611
Front: Jamo s606
Please suggest suitable components for Center, Rear, and Active Sub. Also, let me know if there is any incentive in spending the extra buck on AVR 1911 instead of AVR1611.
Suggestions for a complete system with a budget of 50-60k is also apprciated. Thanks in advance.
Sabhari Nath
Sabari nath, Welcome to the forum.
Please use the search function to search the forum for the info you are looking for. There are many threads about what you have asked.
http://www.hifivision.com/speakers/6809-these-best-speakers-denon-1910-budget.html
http://www.hifivision.com/what-should-i-buy/6882-speakers-go-denon-avr-1910-a.html
http://www.hifivision.com/speakers/11175-speakers-denon-790-aka-1910-a.html
http://www.hifivision.com/speakers/8086-denon-1910-wharfedale-9-6-a.html
http://www.hifivision.com/speakers/7013-speakers-denon-590-1610-a.html
http://www.hifivision.com/what-should-i-buy/8543-budget-speakers-denon-avr-1610-a.html
http://www.hifivision.com/surround-...speakers-denon-avr-1610-need-suggestions.html
AS for denon 1601vs 1910
http://www.hifivision.com/surround-amplifiers-receivers/5968-denon-1910-denon-1610-a.html
Go through these threads, make a shortlist and visit the dealers in your area and listen to the speakers and make a decision.
If you are confused, post on the forum with a specific query.
I hope you get my point regarding the search function, it helps avoid redundancy with similar threads on same topic.
Hi! Make sure you dont mix and match the fronts and the centre the rest does not matter. use the same brand for the fronts and centre to have timbre match and u can mix match the rest. Try wharfedales for they are great value for money speakers. Whats the size of your room to determine what will be suitable floor standing or book shelf.
if by ane chance yu r visisting gurgaon have a look at the centibels the jamo shop they have a 5.1 setup with s608 towers for 61k thats negotiable
conact me if u need the no i have 2 check the no 2 give yu
Iaudio, I was thinking of renaming Spirovious are the Spoogle of HFV. At this rate, I have to find a name for you also!! How does AUDoogle sound? :)
Good work, BTW.
1 more day and a few more auditions. I checked out Monitor Audio M4 & Mourdant 906i :cool:
Both sounded really good and I'm just going to check Wharfedale.
Do I have any other options left in the 30-35k range for front floor-standers? Also, please let me know what could be the best price/deal that I can get for these speakers.
Thanks,
Sabhari
