Sir,I heard the Arrakis in a show last year and the sound was superb, so hopefully there is some trickle down to their lower priced models. Sid
Actually it was a dealer's open house, Goodwins High End, Waltham, MA, last summer.Sir,
Few things;
Where did your listen to the Arrakis ? I have been hunting high & low for it - they never enter a show with it;;;
If you are looking for a Speaker Upgrade - The RT is a Good Contender;
What are the other products you are considering ?
Budget ? So - I may try and ponder over options; New or Used is OK too ?
Visit Mumbai - I will take you around 3 to 4 houses - some set ups to listen to - that way you will get an idea - I suppose...
I never knew Eben was in India - Good to learn;Raidho C1.1 & Evolution acoustics from Auidere
Focal Diablo Utopia from PTC
True;I am also planning a trip to Singapore, hope to be able to audition a lot more options there as well.
Else a in house demo would not be possible.
You must be referring to the older version. Now I believe Raidho calls it C1.1. Yes heard that they will not represent Magico, bummer because I wanted to audition the S1 and fit nicely with my budget.
Not sure about HK, but Singapore definitely.
Sid
I really have no idea on who all provide for home demo though![]()
BTW there is an Awesome speaker for sale on this Forum- The Gradient Active.
I have a significant sum invested in my amp. So will be taking hte passive route.
Pertinent Point;What is the size of your room?
Music that you listen to?
Just for getting the suggestions more narrowed down to make things easy.
Hi Sidvee,
