Anil kumar
Hi Klone here is the breakup.
Woofer 12,000
Tweeter 4,000
MDF 2 boards 1,600
Xover 3,000
Veneer+labour 1,000
Wood cutting 500
Speaker Terminals 300
Dackron poly fill 200
Misc 400
Enclosure is made up of 19mm MDF board. Front is double layered & 4 internal bracing is given to minimise standing waves. internal walls padded with 1" thick sponge & filled with dackron polyfill. Port is tuned close to 37 Hz. Crossovers costed me 3000. Inductors are expensive, most of the xover components were procured from corrson. I am quite satisfied with the output. I have also connected Pioneer vintage paper cone tweeters which sounds better than vifa tweeter, overall sound is neutral, well balanced.
Anil
Woofer 12,000
Tweeter 4,000
MDF 2 boards 1,600
Xover 3,000
Veneer+labour 1,000
Wood cutting 500
Misc 400
Anil
thanks for the info anil. can you give me a rough break up of your cost for your MTM pair? .i cant figure how it would run upto 23K. given the cost of the components and the enclosure made of particle board or mdf? how much did you spend on the 2 Linkey Xovers?
great work by the way. congratulations! i can imagine how much you must enjoy these speakers every day especially since you built everything yourself.
thanks a lot
K
