TD150
If you have already messed the head alignments, you need to try adjust it to the optimum listenable setting.
Sure i will check it out and let you know once I make a trip . Now the stressful taking out of the motor . Screws are like located in the toughest placeIf you happen to go to lamington road, do me a favour, I am looking for a replacement lamp for the play button/ switch glow lamp. It is 24vdc 20mA rating, just see if you can find any shop having it.
These motors cannot be repaired . I opened the entire motor and saw the inside . Basically it's life is over(the bush was like expired and unrepairable)I have no idea about interchanging the motors from different decks. But the main thing to remember is though the other motors rate 12vdc, it is the rpm which needs to be accurate for the reel motor spin the hub reels and the cassette speed may vary. Thus this will have to be set and taken care off.
I would say get the motor to someone who could repair it. Should not be a bit task.
@mshifi I'd really like to know the address of this place as my nakamichi needs thorough looking at . Iam trying to fix the reel motor but there are also other issue s . My record function actually does not record anything even thought there is input being received. Rec lamp needs looking at and I am unable to adjust azimuth for clear playback .( Tried all possible ways slowly steadily)Got my Yamaha AVR and Sansui 717 serviced by them. They are good at their work. Only issue is, you will have to carry the equipment to them and pick it up as well. They do most of the highend brands
