Intended to buy a entry level turntable for records playing. Need guidance from experts of this prestigious group about setting up my turntable + speaker setup in my home....pls give suggestions where to buy LPs/EPs vinyl?
Welcome to HFV.Intended to buy a entry level turntable for records playing. Need guidance from experts of this prestigious group about setting up my turntable + speaker setup in my home....pls give suggestions where to buy LPs/EPs vinyl?
I would suggest reading through the numerous existing threads in this forum about this topic - you will find both pros and things-to-watch-out-for of owning a TT/vinyl today. An hour of searching and reading will save you months in the future.Intended to buy a entry level turntable for records playing. Need guidance from experts of this prestigious group about setting up my turntable + speaker setup in my home....pls give suggestions where to buy LPs/EPs vinyl?
the answer would have been easier if you already had vinyls. But since you have mentioned entry level TTplease remember that good quality vinyls are expensive with new ones at least 2-4 K . Also you will also need a phonostage.Intended to buy a entry level turntable for records playing. Need guidance from experts of this prestigious group about setting up my turntable + speaker setup in my home....pls give suggestions where to buy LPs/EPs vinyl?
No i didnt have those...i am collecting suggestions from expert's now...will buy soon...the answer would have been easier if you already had vinyls. But since you have mentioned entry level TTplease remember that good quality vinyls are expensive with new ones at least 2-4 K . Also you will also need a phonostage.
https://newgramophonehouse.com/ is a place you can check the prices of the vinyl you need.
Do you already have a speaker/Amplifier setup ? if you could share and your budget it will be easier.
I am already making a LPs deal with a seller from his collection..and i am getting good affordable price also.. mainly initially i am collecting bengali LPs then will go for english onesAs others have mentioned, you need to have the “software” (LPs) before you invest in the hardware(TT). Because LPs these days are expensive, especially those that are in VG and above conditions. Collecting them is time consuming too. You’d rather invest a sizeable chunk of your budget in buying LPs and then maybe buy a used gear later. If you are not keen on this hobby after this, you can always sell those LPs.
I am dropping the idea to go with vinyl setup at present due to some problem..As others have mentioned, you need to have the “software” (LPs) before you invest in the hardware(TT). Because LPs these days are expensive, especially those that are in VG and above conditions. Collecting them is time consuming too. You’d rather invest a sizeable chunk of your budget in buying LPs and then maybe buy a used gear later. If you are not keen on this hobby after this, you can always sell those LPs.
