GeorgeO
Can anyone point me to a source here in Bangalore to get suitable gasketing material(rubber?) to use for mounting my mids and tweeters on the enclosure? I'm looking at around 2 mm thickness.
You can get Neoprene sheets easily in Bangalore. Its available in various thickness. I bought 2mm & 3mm @100/- each sheet from JC Road some time back. This shop is right next to Dena Bank after Multilevel Parking on the main road. For mounting drivers would recommend minimum thickness sheet as with thick sheets if you are not careful, probability of bending / breaking driver's mounts is very easy. Still remember Phillips used to bundle approx 1mm normal foam gasket with their Dome tweeters. I have tried bicycle tubes and do not like the idea of rubber protruding out of the sides, have tried trimming that but this stands out like sore thumb. I prefer drivers flush fitted on to baffle.
