I discussed this with Santosh the other day wherein for my HT room, I am currently planing to ALTERNATE between Anutone wall boards (for absorption) AND ply (for reflectrion). Height is 7 ft. So the idea is to have one anutone panel of 7 ft by 4 ft , then the next one of same dimension of ply (both covered by same fabric and backed by glasswool/synth). This way I get a combination of reflection and absorption. Please comment if this is better that having anutone throughout or not.
Some other points :
1. I am putting anutone celing tiles (backed by glasswool/synth) above it.
2. Back of the screen will be full anutone (no reflective ply). Is this ok?
3. Back wall (back of the seating) will also be full anutone (no reflective ply). Is this ok?
4. I have loft on left and right at 7 feet which I am covering with ply. Do I need anutone treatment on the closed wall behind the ply too or can i just leave it with ply ? Remember I am putting a combo of anutone and ply till 7 feet from the floor till loft. It is not possible to take down loft
Manish
Some other points :
Manish
