Hello Everyone,
I'm trying to setup a home theatre setup in one of my rooms whose dimensions are 12'(L) X 10'(W) X 10'(H). I've attached a diagram of the room and the positions where I plan to place the components.
The wall where the screen is planned to be placed has a window which i plan to cover with a curtain so that the screen flows over the curtain. Below the curtain/screen I plan to have enough height placement for a center speaker which will be placed on top of a cabinet containing my devices such as A/V receiver, bd layer, cabel box.
I wanted to know the best screen size I should go in for, to have best possible view as well not hurting the eyes. The projector is an Epson 8350 Powerlite. I plan to place the projector at the opposite end of the wall, wall mounted somewhere around 8 ft from the ground. My assumption is the projector center needs to be positioned at a level which is 1 to 1.5 ft below the start of the projector screen casing.
Should I go in for 106" screen or 92" screen for this viewing distance? I will be using recliner couch set in this room. I got a qoute of around 30K for a VueMax 106" screen.
Any suggestions would be most welcome.
