Remote sensor not working
nokiasony
India
Dear Friends,
I am quite disappointed with my Sony KDL 32EX650. I bought this 30 days back and mounted it on wall. Suddenly, the remote sensor is not working. Tried using the same remote on other tv and found it working. So, i guess remote sensor in my tv would have gone wrong.
Please help me how to fix. Are there some settings that could have caused remote sensor not working. Before this problem, TV was idle for around 15hrs.
Now i want to check upgrading the driver/firmware to check if it can fix the issue or once make the tv to factory defaults. How shall i do?
I am quite disappointed as it is only a month. I bought this in Singapore and it is made in malaysia. Please help me here. Thanks in advance.
-Rukesh
Dear Friends,
-Rukesh
Sony KDL 32EX650 is a full HD Blue Ray Picture Quality, It is has more best Feature but you are facing problem with remote sensor. You know Sony provides 12 Month Warranty so you can call to sony Technical Support they will solve your Problem.
