Hi fellow FMs
Want to upgrade only the speakers in my Dzire ZXI as I feel the dash would loss the beauty and finish, if I go for the HU change. Moreover I may also loss the integrated steering control as well as speed sensing volume control. Hence going only for the speakers.
Though the current system is good for listening FM transmissions, Bass heavy songs from USB and CD makes the speaker to vibrate at a moderate volume level
Would request our fellow FMs to suggest any suitable good component speakers for back and if needed for Front also. Also pls. advise on BASS Tube installation.
Eagerly awaiting for the ADVICE ( on speakers for the existing HU) as all ICE shops' immediate suggestion is for the entire change in the system. My budget is around 15K for speakers.
