Standalone internet player
Sumant
I believe you go through settings,though I can send you more detailed info next week after I return home. You can select the amount of time for buffering.
George
Hi Helium,
Let me answer that. There should be a setting for Buffer time under mysqueezebox.com control panel>Player>Network tab (screenshot). AFAIR, I was using a setting of 20sec when I was on 512kbps speed.
Cheers!
Thanks rydhun for the snapshot. I guess this setting needs to be changed from the PC slim sever installed on the PC as I couldn't locate any setting changes from the remote.
Also I noticed those channels that were streaming 256 Kbps there were constant buffering issues even though I have 512Kbps unlimited.
helium
SB Classic> Beresford DAC 7510 MK4> Lyrita SET 845> Vintage B&W DM4= MUSIC
Sumant
George
Yes George I believe your in the States. I will wait for your expert guidance.
helium
Sumant
I got back yesterday and checked my SB Classic owner's guide.Regretfully I see no mention of how to increase buffer time in the guide.I suspect I may have got confused between the Classic and the Duet.
George
Hi Helium,
Cheers!
Rydhun I reset the bufffer time to 30 and yet there are buffering issues.
helium
SB Classic> Beresford DAC 7510 MK4> Lyrita SET 2A3> Vintage B&W DM4= MUSIC
