No I can not as In case of any brek down I will be stuck in Shimla I Hate to travel with heavy stuff.
Hi Ranjeetrain, Sanjiv Vaid,
Clarification:
I didn't mean to advise using used gear... when I wrote "Used/Matured" against Wharfe 9.2, I meant that this speaker was already "broken in" after perhaps 100 Hrs of useage, hence had potential to give better performance compared to Fresh spkr (Quad, in this case)
However I remember that even as a Fresh piece this 9.2 had better bass than the fresh Quad mentioned above. BTW I don't intend to derate Quad... just telling you frankly what I heard.
Regds,
@murali,hwr ur craftel FS doin?which ones?specs/impressions?have heard that mark makes some very good stuff for the price.any link to his product portfolio?cheers
Hai Rallynut,
The FS is subjected to burn-in , the present Polyamide tweeter is having slightly less treble with my NORGE, hence asked for a upgrade , Mr.Mark has suggested a Titanium tweeter, hopefully to be replaced by next week, and after that I will post the Performance. Otherwise the bass is good, I hope the imaging will improve with the tweeter replacement.
N.Murali.
Hi Sanjiv Vaid,
I recently auditioned following combinations:
Option-1: LG entry level CDP (3k~) + Norge 2060 amp (7K~) + Wharfedale 9.2 "used/matured" spkr (14k~) = 24K
Option-2: Same LG entry level CDP (3k~) + Denon PMA 1500?? (17k~) + Quad 11L "Fresh" spkr (28k~) = 48k
I was surprised to find that, both options sounded equally good (your impression may vary). Wharfe 9.2 was definately better in bass dept. Both spkrs did well in mids and high, though I found the Quad vocals were strained when Neil Diamond's rich baritone vocals hit strong peaks, whereas 9.2 handled them without fuss.
My suggestion to you: More money doesn't ensure more performance. Do audition the option-1 above before auditioning big budget options.
Regds,
are you absolutely sure?!!
Quad beats Wharf 9.2 hands down throughout the frequency spectrum.
I can tell this because I auditioned both plenty of times with Norge 1000 amp, as well as doing A/B on Denon stereo amp.
Wharf were buzzing when I turned the bass up (keeping the volume high). and vocals were submerged, whereas in Quad, vocals, violins, piano, guitars (essentially midrange instruments) in general stood out.
High end in both was smooth and soft, not harsh.
I agree to the fact that more money does not translate to more quality, however, Quads and Wharfs - no comparison, whether broken in or not!
Hi Sanjiv Vaid,
Regds,
I second sonsphere. I have setup recently one for under 30K in fact 24K to be precise. Norge 2060 (landed cost Rs. 8,500) + wharfedale 9.2 (Rs. 15,100) + DAC cables (Rs. 450) with a mass market DVD player. I should say im satisfied with the sound quality. BTW, i hear rock, hip-hop, pop, tamil songs. The setup does a clean job of all, although 9.2 still has to fully break-in. It would only get better as 9.2 matures.
DEAR ALL,am looking to buy a combo of bookshelves and amp.my budget is around 20-25k only.basically am into listening Tamil film music of late 70s to 90s particularly ILAYARAJAS.the trouble is the audio available in those times were not of good recording quality.so looking for speakers to match them.expecting good bass from the speakers.also most of my collections are in my HDD IN MY PC.so the speakers and amp should be able to be connected to the PC.I might use /shift the speakers to the living room of SIZE 10 FT BY 15 FT in case of friends dropping over.just trialled the BOSE 301 SERIES .basically for the STEREO EVERYWHERE they promise!.also wld like to know whether they would sound good while watching movies in the living room.have zoomed in in on the following
SPEAKERS;
1.BOSE 301 SERIES
2.WHARFEDALE9.1&9.2
3.POLK RTI A1
4.POLK TSI 100&TSI 200
5.NORGE NEW MILLENIUM
6.MORDAUNT 902
7.ATRIUM 45
AMPS;
NORGE 2060/NORGE1000
Kindly guide me for the above please.hope to hear from u guys soon.rgds.visu
Besides above needs, I also listen to lot of south Indian classical stuff (both good quality CDs and old recordings mostly in MP3 on my HD). I would add a SW may be a few months later. If not Norge what else would be good. How about an all-in-one like CA One? Or Audioengine powered speakers with a good source. I am actually confused as you can possibly see from the question.
Thanks in advance,
Srivats
dear all, is it a simple case of GIGO as far as poor recording quality is concerned.or does speakers work up a magic.waiting for ur comments.rgds.visu
Hi visva,
Norge 2060/1000+Wharf 9.2 will be an ideal choice. A while back when our member murali came to check his Norge amp with my 9.2s we played a song from Alaigal Oivathillai sung by Ilayaraja.We were very impressed the way the song sounded. raja's voice sounded as if he was in the room.
cheers,
sri[/QUOdear all, i would like to know from the dear members something about speakers for mono recorded music.as you are all aware most of music as far as Indian music is concerned were recorded in Mono sound till about early eighties.Now we discuss extensively about how good 2.0 channel is for Music. then what about SPEAKERS/AMPLIFIERS for Mono recorded music say the golden oldies of 60s of hindi cinema and Tamil cinema or for that matter 70s inidan film music.i am sure many in this forum are great patrons of these music. now how good is stereo speakers or 2.0 channel stereo speakers for this Mono sound,as many of my collections is in MONO recording.rgds.visu
