Taga - TAV 606 V3 - 5.0 Speaker System
No problem bro. Most of the things I have learnt here on this forum only.
Sent from my ONEPLUS A3003 using Tapatalk
@TAV-606 Se owners-
Have you tried these towers in dedicated stereo set up?
Can these deliver enough bass like wharfedale?
For HT, they look solid to me.
@TAV-606 Se owners-
Hooked wit marrantz vintage series! I never heard tat much solid and crisp details and punch in my fs before! Bt bass is bit low! If u giving more try out Means it will never fail u in terms of quality!
Sent from my vivo 1601 using Tapatalk
Are centre and rears clear and can provide Good moVie dialouges and Effects or not which amplifier You are using brother
For begining just go wit this package for movie use! Sound was pretty decent! Increase the levels in avr for centre and rear! Simple! When u find money then go for other surround brands! It's pure vfm product ! Simple and sweet! Movies r really enjoyable
@TAV-606 Se owners-
I own Taga 606 se package and is using it with Yamaha RX V 481 AVR. Have played flac/mp3/movies in Direct/Stereo mode and the floor standards does a good job. Sound is smooth and natural. I turn the volume to 65 percentage max and the FS gives remarkable crystal clear audio to fill my room of 12ft x 20 ft.
As far as bass is considered dont think its that bass heavy FS like wharfedale but does decent jobs with movies as well as music. I do not have a sub currently do miss sub while watching movies but dont miss them when listening to music.
Hi Arjuraj,
Can you please tell me how to increase the levels for centre & rear?
I just auditioned Taga speakers and they are pretty good with movies. But when the shop guys played some mp3, they didn't sound so well. Or may be because the volume was low?
Hi everyone ! i'm new in this forum ! also in Hi-end sound system, actually i'm a little bit Confuse with my setup, please suggest ! I have purchase "Taga 606 V3" for "Onkyo TX-SR309" AV Power is 120W at 6 ohm, speaker power is 20-120W at 6 ohm, AV get hotter within 5 min,
Is There any problem with power matching ? Please suggest !
That AVR is rated at 120 w with one channel driven. With two channel driven it will be lower, leave alone 5 channel driven. And your listening volumes will be much lower than the peak output of AVR. So your speakers would be just fine.
The AVR can get a bit hot especially in summer. Ensure good ventilation all around it.
Thanks Dear ! Please let me know, is there my speaker is under power ? actually i have zero knowledge about this ! AV Power and speaker description as below, Please help me to understand the power description, is this setup is recommended or not ?
AV Power
Front L/R -
120 W/Ch(6 ?, 1 kHz, 1%, 1 channel driven, JEITA)
100 W/Ch(6 ?, 1 kHz, 1%, 1 channel driven, IEC)
65 W/Ch (8 ?, 20 Hz20 kHz, 0.7%,2 channels driven, FTC)​
Center -
120 W(6 ?, 1 kHz, 1%, 1 channel driven, JEITA)
100 W(6 ?, 1 kHz, 1%, 1 channel driven, IEC)
65 W (8 ?, 20 Hz20 kHz, 0.7%,2 channels driven, FTC)​
Dynamic Power -
160 W (3 ?, Front)
125 W (4 ?, Front)
85 W (8 ?, Front)
THD+N (Total Harmonic Distortion + Noise)
0.08% (20 Hz20 kHz, Half power)
Damping Factor 60 (Front, 1 kHz, 8 ?)
Input Sensitivity and Impedance - 200 mV/47 k? (Line)
Rated RCA Output Level and Impedance - 200 mV/2.2 k? (Rec out)
Maximum RCA Output Level and Impedance - 2.0 V/2.2 k? (Rec out)
Frequency Response - 20 Hz50 kHz/+1 dB, -3 dB (DSP bypass)
Signal-to-Noise Ratio - 100 dB (Line, IHF-A)
Speaker Impedance - 6 ?16 ?​
Speaker Power
Design - 3way, crossover points 500Hz 3.8kHz
High-Frequency Driver - 25mm (1"), TWG faceplate
Mid range Driver - 133mm (5.25")
Bass Driver - 2 x 165mm (6.5")
Recommended Amplifier Power - (20-120W)
Frequency Response - (40Hz-25KHz)
Impedance - 6 ohm
Sensitivity - 90 dB​
Receiver provides power and speakers handle that power. So speakers can't be 'underpowered'.
In your case the speakers have sensitivity 90 db so should be easy to drive.
In general, if you pair entry level receiver with entry level speakers, you can't be wrong.
Taga speakers good for movies! Not pleasant for stereo! Lacks a lot of details and no depth in it!!
Hi Arjuraj,
In your avr speakers setting try to change speakers level or distance and keep trying your desire sound level! Increase the numbers and try
May I know Where did you auditioned them? What is the amp you have paired it with? And hat is the source player?
Sent from my Lenovo K50a40 using Tapatalk
I feel the same.In HT, subwoofer handles bass frequencies and so they work perfect.In music not much depth and lack some weight.
Guys,
If you forget the specs and trust our years, is there any drastic noticible difference in sound quality and volume between taga harmony 506,606, and 606SE ???
Thank you in advance, Naveen
