Better 2D PQ - Sony W700 or W800
maddy_kumar_p
Chennai
Guys,
In terms of 2D PQ between Sony W700 and W800, which is better.
Does W700 have local dimming.
Think W700 uses VA panel. Does it mean it has better black level than W800 using IPS panel.
Help me out in selecting between the two.
Budget 85k, Viewing distance 7 Ft , 3D not a priority.
Guys,
1) Both have same 2D quality.
2) No local dimming in either W700 or W800
3) Only W9 series uses VA panel. Rest all use IPS panels.
Since 3D is not a priority, W700 should be purchased.
BTW, you haven't specified the screen size.
@Sanjeevji thanks for the info man. But hw sure are you with this IPS panel on W700?? Can you give me a source.
So the black levels are identical between the two is it??
My budget is 85k so it'll be 42W800 or 47W700.
